Thread: Batch Process files to a earlier version using Save AS
    2003-06
    38
    Default Batch Process files to a earlier version using Save AS
    Many thanks in advanced,
    We are sending files out to bid and have a contractor that can not use our files in 2008 format. I need to be able to do a batch process on multiple files at a time saving to a 2004/2005 format. Has anyone done this?
    Thanks, Mike
    2007-09
    490
    Default Re: Batch Process files to a earlier version using Save AS
    Use ETRANSMIT from the "File" menu.
    Click on "Transmittal Setups" then "Modify."
    You will see a drop-down menu where you can choose the file format. Pick 2004.
    HTH
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Quote Originally Posted by mserapiglia View Post
    Thanks, Mike
    You may try DWG Trueview which is free and has the capability to convert drawing versions. You can download it from Autodesk site.
    2,095
    Quote Originally Posted by zoomharis View Post
    And make sure the other company has a copy as well so they can convert files on their own if they have to.
    125
    Send PDFs or DWFs not DWGs
    ACote
    2003-06
    38
    Thanks for the help...
    I will download and give a try, so DWG Trueview will convert "multiple files" !!
    That is what I need, Thanks!
  1. 2012: Save to earlier version automatically
    By andrewp in forum AutoCAD General
    Last Post: 2011-08-03, 12:58 PM
  2. Batch, save as, to earlier CAD version
    By wardorichie in forum Design Review - General
    Last Post: 2008-07-23, 12:55 PM
  3. Batch export to an earlier version of CAD
    By .chad in forum AutoCAD Customization
    Last Post: 2007-06-12, 07:10 PM
  4. save to earlier version
    By iffans in forum Revit Architecture - General
    Last Post: 2005-04-08, 05:59 AM
