Results 1 to 10 of 20
Thread: chain Link fence
    I could stop if I wanted to jarod.tulanowski's Avatar
    2001-12
    Columbus, Ohio
    313
    Default chain Link fence
    Does anyone know how to make a chain link fence that also renders? I know how to make one if it is just a cross hatch pattern on a thin wall, What I really would want is a wall that you can see through beyond in an annimation and also see the chain link in front. any ideas? Thanks in advance for the feedback
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: chain Link fence
    You can use a material which when rendered is partially transparent. I posted notes on the method way back when. The principal is described over here.....http://forums.augi.com/showthread.ph...ighlight=quick
    2004-06
    18
    I've got this from one of the forums awhile ago.I hope this will help you.
    2001-12
    Columbus, Ohio
    313
    Talking Re: chain Link fence
    Thank you very much. well here is my first try haha
    Ahh I love the smell of chain link in the morning!
    Check out the chainlink fencing I did in revit, not to bad shadows sky reflections and all. I have attached the revit model for you to play with at your convenience.
    100 Club Nevine's Avatar
    2003-05
    Cincinnati
    123
    I created this chain link fence as a railing with a panel fill. I assigned to the panel a material with tile. The base is trasparent and the tile is oriented to 45d and 2" spaced.
    2001-12
    Columbus, Ohio
    313
    cool
    that was what I was also doing. one additional step that I did was put a post family in and have it calculate a new post every 10 feet if I stretch the wall out. this worked great on a site fence.
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Quote Originally Posted by Nevine
    That's brilliant. A tip! A tip!
    2009-06
    Would you be so kind as to attach the chain link fence you made as a railing? Or, would you please give a detailed explanation of how you did this? I am trying to make my own, but not having much success! Thanks!
    Pittsburgh, PA USA
    1,906
    Railings are system families and cannot be saved to a file
    2006-06
    Toronto, ON
    2,386
    Unless they paste it into a blank Revit file and post it here, so you can copy and paste into your own file.
    But just create a new material using a cross pattern (model pattern) at 45 degrees and make it 100% transparent. The result of that material is that only the model pattern will show. Then use it as a material for your railing.
    Andre Carvalho
  1. Chain-Link Fence
    By Chowdur in forum NavisWorks - General
    Last Post: 2013-08-20, 11:25 PM
  2. chain link fence
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2011-02-17, 01:11 AM
  3. Any Chain Link Fence in 2011?
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2010-09-01, 01:12 PM
  4. Chain link fence gates anyone ??
    By j_starko in forum Revit Architecture - Families
    Last Post: 2006-11-07, 04:04 PM
  5. Chain Link Fence
    By Steve_Stafford in forum Revit Architecture - Families
    Last Post: 2003-09-05, 07:13 PM
