Thread: material surface patterns on split regions walls won't update
    2007-01
    33
    Default material surface patterns on split regions walls won't update
    I have created a wall that has three different materials split horizontally. I used the split region to modify the vertical structure of exterior wall layer under wall edit assembly. This went fine but now I'm trying to revise the surface patterns, I revise the surface pattern for the material but it does not update on this wall type. The material updates on other walls using it and I can paint the material onto this wall and it paints with revised pattern but the wall itself won't change. Is this a bug, a feature! or am I missing something.
    Pittsburgh, PA USA
    1,906
    Default Re: material surface patterns on split regions walls won't update
    Quote Originally Posted by davidthigpen View Post
    Are these three materials that happen to use the same surface pattern, like 3 different colors of brick? This can sometimes cause an issue. I've had to duplicate the material, and define a surface pattern with a different pattern name (loaded from the same PAT file, to get these to be shifted independently.
    Member nblevins's Avatar
    2016-01
    New Orleans, LA
    41
    i just had a similar problem on a wall type that's divided horizontally within the wall properties. the sections have different materials, each with a different pattern, but the patterns weren't updating automatically when i changed them.
    i finally realized if i used the paint bucket on the sections that had changed, but painted with "by catagory" they would change each time... even though they were supposedly already showing their default pattern.. i tested it several times to be sure.. seemed like a bug to me.
  1. 2013: Corridor Top surface split by material
    By PytorOuspensky in forum AutoCAD Civil 3D - General
    Last Post: 2013-06-05, 06:05 AM
  2. Material Surface Patterns
    By edenvaughn in forum Revit - Platform
    Last Post: 2009-11-06, 08:17 PM
  3. Use Walls with Surface patterns for curtain walls in Early Design
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2009-01-13, 10:21 PM
  4. Grayscale in surface patterns and filled regions
    By AUGI Strangelove in forum Revit Architecture - General
    Last Post: 2008-10-24, 07:44 PM
  5. Split regions in roofs & slabs - wraps in walls not calculated
    By sdm.77920 in forum Revit Architecture - Wish List
    Last Post: 2007-04-02, 07:14 AM
