Results 1 to 7 of 7
Thread: linetype doesnt print correctly on the xref
    I could stop if I wanted to mickaeL_renauD's Avatar
    2008-02
    Los Angeles, CA
    248
    Exclamation linetype doesnt print correctly on the xref
    I checked the setting of “psltscale”. Another possibility i tried was the individual lines have their “ltscale” properties set to a value other than 1 or the line type has been set to something other than “bylayer”. also checked layers...
    what is going wrong here?
    Mickael Renaud
    MEP Design Engineer
    | Less is only more where more is no good |
    2006-12
    Big "D"
    3,711
    Default Re: linetype doesnt print correctly on the xref
    Quote Originally Posted by duaner ekim View Post
    so psltscale is set to 1, right? Are you viewing it in model space or paper space? If it's model space, set msltscale to 1 also, then do a regen.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2008-02
    Los Angeles, CA
    248
    Exclamation Re: linetype doesnt print correctly on the xref
    Quote Originally Posted by dzatto View Post
    I did all of that...
    I have a sheet file that doesnt print a linetype out right but when i go into the sheet file it prints correctly. The problem is with one of the layers "A-CLNG-DIM"...on the original file, it is set to a certain linetype, and when u plot from there, it plots correctly…yet on the xref sheet file the linetype does not plot properly.
    Deadlines suck
    Mickael Renaud
    MEP Design Engineer
    2003-08
    112
    Make sure the linetypes are the same on both files
    2005-06
    in the upper right corner
    3,305
    Deadlines suck
    Is your variable "visretain" set to 1?
    And did the linetype get changed in xref (or the plot sheet) during the process?
    You could set visretain to 0, reload the xref and then set it back to 1 (but you will get the xref in what ever state its saved at, so be careful)
    Or you could simply change the linetype in the plot sheet xref layer to match the xref base,
    That layer name would look something like: Xref|A-CLNG-DIM
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    2008-02
    Los Angeles, CA
    248
    Still have problems after all of that.....?
    Mickael Renaud
    MEP Design Engineer
    2006-12
    Big "D"
    3,711
    Okay, try copying the host drawing into a clean template, then Xref the drawing with the linetype in question. See if that works.
    RevitForum.org
  1. 2010: Xref layers do not print correctly when hiding lines
    By keith9769 in forum AutoCAD General
    Last Post: 2012-10-30, 06:33 AM
  2. 2013 doesnt refresh the xref's
    By drewj in forum NavisWorks - General
    Last Post: 2012-06-07, 11:11 PM
  3. trouble getting certain layers to print correctly
    By ferriein in forum Revit Architecture - General
    Last Post: 2008-11-20, 06:22 PM
  4. Zig Zag Linetype not displaying correctly in AutoCAD 2007
    By bDOUGH15 in forum AutoCAD General
    Last Post: 2007-05-29, 10:22 AM
  5. Custom complex linetype not displaying correctly in Xref
    By JASONM30395 in forum AutoCAD Customization
    Last Post: 2005-07-27, 11:17 AM
