Thread: GFI Outlet Label in Elevation View - Revit 2008
    2002-12
    Philladelphia, PA
    72
    Default GFI Outlet Label in Elevation View - Revit 2008
    Hi,
    I'm trying to create a custom Electrical GFI Outlet from the OOTB Outlet GFI family and have the label show in elevation as opposed to plan, but for some reason I don't have the option to insert the label in an elevation view. Is there a setting I need to check to allow me to do this?
    Thanks,Jim
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Default Re: GFI Outlet Label in Elevation View - Revit 2008
    Ugly workaround:
    I make a DWG with the text I need and put it in the elevation view of the RFA.
    2002-12
    Philladelphia, PA
    72
    Quote Originally Posted by truevis View Post
    Ugly workaround:
    Oh man, that's what I was afraid of. Thanks for the reply, though. Can you assign different DWGs to different Types within the family?
    Anyone else?
  1. Label in Electrical Fixture family - Revit 2008
    By jmarchese in forum Revit Architecture - Families
    Last Post: 2009-02-11, 04:48 PM
  2. Door Swing Elevation Lines - Revit 2008
    Last Post: 2008-09-25, 09:04 PM
  3. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
  4. Revit 2008 - Toolbar - Text label??
    By ejc in forum Revit Architecture - General
    Last Post: 2007-04-13, 01:04 PM
  5. dwg files in Revit Elevation view
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-02-20, 07:00 AM
