Thread: Lisp required to find all the entites which are not parallel to the current ucs and not in the same plane
    2007-05
    23
    Default Lisp required to find all the entites which are not parallel to the current ucs and not in the same plane
    Hi
    I Need a lisp where the lisp will search all these elements
    1. Which are not parallel to the ucs.
    2. Entites place in the Z axis
    3. Any entity with Z Co-ordinates.
    Balu
    2005-06
    CORDOBA-ARGENTINA
    275
    Default Re: Lisp required to find all the entites which are not parallel to the current ucs and not in the same plane
    Quote Originally Posted by balubharadwaj View Post
    Hi
    Balu
    Can you , please, upload a DWG sample? or send it offline
    2007-05
    23
    Hi
    just look at the testing.dwg
    i need all entites marked in red to be listed when i run the lisp
    balu
    2005-06
    CORDOBA-ARGENTINA
    275
    Hi
    balu
    Where do you want the objects to be listed.?
    Are you making a lisp ?
    If so , can you show me?
    What time , hour is where you are now ?, here is 11 am on 30-jan.
    2007-05
    23
    I need the entities to be listed in the command prompt
  1. Selection Window to be Parallel with current UCS
    Last Post: 2016-12-03, 03:06 PM
  2. 2011: Reorient an object in space to be parallel a principal plane
    By dpriedel.255136 in forum AutoCAD General
    Last Post: 2010-07-07, 07:42 PM
  3. Replies: 6
    Last Post: 2009-11-12, 03:32 PM
  4. Attaching to non parallel work plane?
    By scowsert in forum Revit Structure - General
    Last Post: 2007-12-19, 09:12 PM
  5. TO FIND A REQUIRED DRAWING
    By Vladimir.Levine in forum Networks
    Last Post: 2004-08-10, 06:23 PM
