jfields.61630
This can be done. Take the item that is modeled and place it in particular position that you desire. Say top view , then type the command "flatshot" on the command line ACAD will then create a block of this view complete with hidden lines, or at least it will as long as you tell it to in the flatshot dialog box. This creates a block of the required view. Then just name the view, go to the layout tab and create viewport, type view, select desired view, and pick the viewport you wish it to be displayed in and there you go. I think it is easier than the soldraw command. Give it a try, maybe it will work out for you.
