Hi,
Another way is to write the DCL from the LISP in a temporary file.
Here's a little example:
;; ListBox (gile)
;; Dialog box which allows a single or multple choice
;; Arguments:
;; title : dialog title (string)
;; msg ; message (string), "" or nil for none
;; keylab : assoc list which type is ((key1 . label1) (key2 . label2) ...)
;; flag : 0 = popup list
;; 1 = single choice list
;; 2 = multiple choice list
;; Return : the key of the choosen option (flag = 0 or 1) or the key list (flag = 2)
;; Example:
;; (listbox "Layout" "Choose a layout" (mapcar 'cons (layoutlist) (layoutlist)) 1)
(defun ListBox (title msg keylab flag / tmp file dcl_id choice)
(setq tmp (vl-filename-mktemp "tmp.dcl")
file (open tmp "w")
(write-line
(strcat "ListBox:dialog{label=\"" title "\";")
file
(if (and msg (/= msg ""))
(write-line (strcat ":text{label=\"" msg "\";}") file)
(write-line
(cond
((= 0 flag) "spacer;:popup_list{key=\"lst\";")
((= 1 flag) "spacer;:list_box{key=\"lst\";")
(T "spacer;:list_box{key=\"lst\";multiple_select=true;")
file
(write-line "}spacer;ok_cancel;}" file)
(close file)
(setq dcl_id (load_dialog tmp))
(if (not (new_dialog "ListBox" dcl_id))
(exit)
(start_list "lst")
(mapcar 'add_list (mapcar 'cdr keylab))
(end_list)
(action_tile
"accept"
"(or (= (get_tile \"lst\") \"\")
(if (= 2 flag) (progn
(foreach n (str2lst (get_tile \"lst\") \" \")
(setq choice (cons (nth (atoi n) (mapcar 'car keylab)) choice)))
(setq choice (reverse choice)))
(setq choice (nth (atoi (get_tile \"lst\")) (mapcar 'car keylab)))))
(done_dialog)"
(start_dialog)
(unload_dialog dcl_id)
(vl-file-delete tmp)
choice
;; STR2LST
;; Transforms a string with separator into a list of strings
;; Arguments
;; str = the string
;; sep = the separator pattern
(defun str2lst (str sep / pos)
(if (setq pos (vl-string-search sep str))
(cons (substr str 1 pos)
(str2lst (substr str (+ (strlen sep) pos 1)) sep)
(list str)
This way, allows to create the dialog box differently according to parameters got by the LISP before writing the file.
In the attached file, SSD is used to make a dynamic blocks selection filtered by their dynamic properties. The dialog box to choose the properties is created after the choice of a target block and matches its dynamic properties.
