Results 1 to 8 of 8
Thread: Navisworks Freedom 2009 vs. Autodesk Design Review 2009
    2016-01
    San Francisco, CA
    293
    Default Navisworks Freedom 2009 vs. Autodesk Design Review 2009
    Since both of these free programs can open up the 3D DWF file, my question is which program do you typically ask your clients or consultants to use when you share/exchange the information?
    I personally like the Autodesk Design Review 2009 very much. That "white outline" of the cross section is really cool when trying to demonstrate where that cut essentially occurs, it really emphasizes where the cut is. Can Navisworks freedom does things like this?
    The only thing I don't like about ADR 2009 so far is the inability to print it a high quality PDF file, like the way you can from Revit directly (pump up the dpi all the way up to 600 dpi.)
    I would love to hear professionals like you guys who can share your thoughts on these 2 products, thanks in advance.
    2000-01
    Seattle WA USA
    5,859
    Default Re: Navisworks Freedom 2009 vs. Autodesk Design Review 2009
    Navisworks Freedom does not allow you to freely section the model, whereas Design Review does. We use Freedom only to view models where the full version of Navisworks is used in project coordination.
    IOW, they both have their uses, andvantages, and disadvantages. We just use the best tool for the task, given that we have different tasks.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2009-01
    68
    I was just using NavisWorks Freedom this morning and looking for cross section capability. As good as NavisWorks Freedom is to navigate models that is a fairly large deficiency that functionality is not included. Hopefully it will be soon.
    100 Club mitch.cornelius's Avatar
    2008-05
    Salt Lake City, UT
    171
    My biggest problem with Design review is the difficulty in navigating large models. Ona large project, Navisworks works fine but Design review can be very clunky.
    2016-01
    San Francisco, CA
    293
    So in other words, if Navisworks Freedom 2009 has the section capability, we can pretty much disregard the Autodesk Design Review 2009.
    I think the section tool in ADR 2009 is so useful to discuss where the conflict is, especially during the online meeting situation.
    Hopefully this will be added to the Navisworks Freedom 2010 version.
    100 Club steve.perkio's Avatar
    2006-05
    Riverside, California
    140
    Are you trying to use Freedom Viewer for coordination meetings?
    That is what I gather from your quote below, if that is the case, you're behind the curve.
    Are you a Coordinator, or MEP Manager?
    What field are you in?
    Perk
    Quote Originally Posted by diesellam View Post
    2016-01
    San Francisco, CA
    293
    I'm a BIM coordinator of a general contractor firm.
    Most of the files I've been getting are created by some 3rd party softwares. They saved them as .dwg files. Then I imported those .dwg files in Revit. And I can either export them as a 3D DWF or export them to Navisworks.
    I've been playing the ADR 2009 and Navisworks Freedom 2009. It seems to me that the cross section tool is a very powerful tool to make the viewers recognize exactly where the conflicts are. And I do agree with the other people saying that it's faster to navigate in Freedom when the model is getting bigger. So I was saying if Freedom has this cross section tool, then it may not be necessary to use ADR 2009 anymore since that's the only the thing Freedom can't do for the time being.
    2015-12
    2,095
    No question for us, Freedom all the way. We use the licensed Review for, well, reviews. Sectioning isn't a huge deal, if something is in the way it gets set to transparent or hidden as required before publishing, or a separate NWD file is created. The big thing for us for Freedom over 3D DWF (and even Freedom v5.x) is the properties - clients can inspect components as required.
    I don't think ADR has "Bob", either. Not totally reliable, but he's a decent enough judge of whether somebody will have access to parts of the plant.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
  1. Object enablers for MEP 2008 NavisWorks Review 2009
    By doug.angerman in forum NavisWorks - General
    Last Post: 2008-08-06, 11:55 PM
  2. Correcting Building Orientation in NavisWorks Freedom 2009
    By bgunderson in forum NavisWorks - General
    Last Post: 2008-07-08, 04:43 PM
  3. manually remove all components of Navisworks Freedom 2009
    By kyuen in forum NavisWorks - General
    Last Post: 2008-05-13, 06:10 PM
  4. Design Review 2009??WTF
    By jhohman in forum Design Review - General
    Last Post: 2008-04-18, 08:56 PM
  5. Autodesk Design Review 2009
    By Filipe Francisco in forum Português - AutoCAD / AutoCAD LT
    Last Post: 2008-03-25, 11:29 AM
