These are poping up all over our drawings and I don't know how to get rid of them. Any Advice?
The red circles are indicating that there are wall clean up issues. They should already be non-plotting by default, you can check this or turn them off completely by going into the display properties for the walls.
A better option would be to play around with the walls to make them clean up correctly.
This thread may be of help too.
http://forums.augi.com/showthread.php?t=48110
Select the wall, right click then pick edit display properties, click the button in the top right of the dialogue box that appears and it waill take you to the display properties which is similar to the layer manager, there should be one called defect warning, click the light bulb to turn it off.
Does that help you?
I don't know how tight your tolerances are for the type of work you're doing but, you might want to have the Archie tighten those walls up first. It's possible there's a significant enough error in the wall they'll end up moving it and throwing all your work off.
That or they'll see the error, go looking closer and come up with a shiny new design and ftp it to you at 4:30pm Friday with a deadline of 8:00am Monday morning..
Raise your hand if that last one has ever happened to you..
