I have problem about object data value (import from DGN file).
Object data value in AutoCAD Map 3D 2009 version incorrect but AutoCAD Map 3D previous version correct.
Please see attach file...
A lot of things broke over the last few versions in the map import. Only work around is use the old mapimport4 command. That's the Map4 command that's still a part of MAP3D that the development hasn't touched in the past few years.
Thank you for you inform but mapimport4 command can not solve this problem.
However I hope you will find the way to solve this problem.
Best regards.
