Results 1 to 8 of 8
Thread: MEP Family Storage
    2006-07
    32
    Default MEP Family Storage
    I'm failry new to Revit and I'm looking for some ideas on where to store our companys families. I don't know if I should combine all of our custom families with the out of the box content or create a new folder and duplicate the folder structure. I thinking that I should at least split it up by release since we are working with different firms that are using different releases.
    Thank you
    All AUGI, all the time mwiggins121466's Avatar
    2006-09
    576
    Default Re: MEP Family Storage
    We keep out of the box seperate. Also we split by releases.
    Margaret Wiggins
    Revit MEP 2006 and Greater
    Electrical Designer
    Detroit, Michigan
    wigginsm@yahoo.com
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    You are on the right track - keep it separate from OOTB, and duplicate the folder structure.
    Christopher Herr
    Studio H:T
    Republic of Boulder
    I could stop if I wanted to RevitNinja's Avatar
    2007-09
    490
    I'll share my method for organizing families. I started working with Revit just months before 2009 hit the market and was in the middle of a project when my company upgraded.
    Excluding the content released by manufacturers, I work with three types of families:
    1. OOTB
    2. OOTB that has been edited for company use
    3. Company-created
    The file names of family types 2 and 3 are suffixed with (TOLK), which is the name of my company. Any family that has been edited or created by us gets the (TOLK) added to its file name.
    My reasoning? When you are ready to upgrade to a new release, you can simply run a search for all families containing your company suffix. You can then choose which families you want to bring with you when you migrate.
    Hershey, PA
    352
    Quote Originally Posted by SAMeyrow View Post
    1. OOTB
    3. Company-created
    This is what we do as well, and the method I think is most common from what I've seen and heard.
    Timothy S. Kramer
    Sr Mechanical Designer
    "Just because you can doesn't mean you should!!!"
    "You don't know what you don't know!"
    What am I doing HERE??? I should be riding my Road King!
    2006-07
    32
    Smile Re: MEP Family Storage
    All - Thanks for the responses
    100 Club sven.129574's Avatar
    2006-12
    101
    What we do is very similar to what Seth and Timothy do. That way, you don't have to look in the company directory, see that "Nope, we don't have our own version," change to the OotB directory, and use one from there. You only have to look in one directory for any particular type of thing.
    Just make sure that that EVERY custom family filename has the exact same sequence of characters in it, and no OotB family will never have that string.
    Scott E. Johnson, Ph.D.
    Production Software Manager
    Osborn Engineering
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    We have maaany many shared parameters with our families, so we have an extensive process in family creation. Therefore, we generally keep our OOTB families in a completely different place, and only move them to our "standard" folder after we do an overhaul.
    Most of our families are complete customs though.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
  1. 2012: Stage Storage
    By jenniferchavez in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2012-04-28, 02:40 AM
  2. Variable Storage
    By cosmarchy in forum VBA/COM Interop
    Last Post: 2012-01-19, 04:01 PM
  3. Network Storage
    By .chad in forum Networks
    Last Post: 2008-11-01, 10:51 PM
  4. storage systems
    By rjjlee in forum Revit Architecture - Families
    Last Post: 2005-09-26, 11:46 PM
  5. Looking for Recommendations on Storage
    By Hippigypsy in forum Hardware
    Last Post: 2004-09-04, 03:44 PM
