If you mean you want to move it to an offset side, as if you do an offset then delete the original. You can do this with the OFFSET command. When asked for the Offset distance, type E (for Erase) and Y (for Yes delete source object). Here's the command line:
OFFSET
Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] <40.0000>: e
Erase source object after offsetting? [Yes/No] <No>: y
Select object to offset or [Exit/Undo] <Exit>:
Specify point on side to offset or [Exit/Multiple/Undo] <Exit>:
