Whenever I go to add a branch line to an existing pipe, I select the pipe and click on the little white cross to add pipe. This is always located in the middle of the pipe run and I end up moving it to where I actually want to put the pipe. Am I missing something here?? Is there another way to go about this so I can add pipe right where I want to add it using the white cross method or should I use another method?
