greetings all
I have an Ipart that I got from CBliss.com and I've edited it to have our part numbers etc. The problem then comes from when I publish it to my content center. Whenever I go to place any from the content center in the assembly, they all place identical to whichever member I was viewing when I published. (IE: if i published while i'm looking at the 4 pin, when i go to place anything from 2 to the 16 pin, it goes in with the numbers and description correct but the representation is as the 4 pin.)
I may be missing some fundamental setting of IParts, any advice is appriciated!
Rod
-The problem looks like it does not pull in the "Pin" property. any ideas?
thanks!
