The idea of Revit and BIM is to increase productivity, and decrease coordination time....
I'm working for an International multidiscipline consultancy based in New Zealand, with offices in Australia, UK, and Canada. We are in the process of implementing Revit Structure, MEP, and Revit Architecture has been used for a number of years now.
The problem I am having is collaboration. I have tried a number of approaches, linking and copy/monitor on my first project (a very small refurb) it worked ok, but the problem comes when Architects delete things, and re-model elements.
The next one was a single cnetral file with both Architecture and Structure collaborating, this was a new build school block, with refurbishments to existing classrooms, a much larger project than the first one, I found this to work really well although I know it is not the "advised method."
I'm currently working on a new build aquatic centre, 4 swimming pools, 2 storey, sloping roof, a combination of timber and steelwork, with concrete columns, not overly complex but tricky enough. We started the design stage pretty early, the architects were still updating and revising their model, as I was modeling the structure. We opted for the linked approach as they are an external company.
Having modeled most of the structure, foundations, steelwork, roof framing, pre-cast panels for the pool walls, I receive an updated architects model and they have dropped the floor level, pool level, roof level, made the building footprint bigger, moved 2 of the pools, and on top of that when making the changes deleted and re-modelled walls, grids, floors, etc.
So the problem I face is number one, a long list of co-ordination warnings, having to delete and re-copy elements, in addition the time it will take to drop all the levels. Initially my framing was locked to the U/S of the rood, but because the architects have deleted and re-modeled the roof, it doesn't exist anymore, a very painful task and I am contemplating starting from scratch... I know this is the kind of thing we are used to from our AutoCAD days but it is far easier to manipulate linework in 2D, I think the workflow needs to change when using Revit, the Architects will need to have the model pretty much finalised before the structural model starts, what do you think?
How are other companies approaching collaboration? Single or Linked files? Should the Architectural model be 90% complete before the Structural model is started? Or do we just accept the architetcs will make loads of changes, and get on with it...
I don't think the "collaboration tools" in Revit are as good as the resellers make out, but also users need to be educated in the use of such a powerful tool if we want to make it work.
What are your thoughts?
Thanks.
Glenn
