Results 1 to 10 of 10
Thread: Match Properties
    2008-10
    45
    Red face Match Properties
    Hello All,
    I have a problem with a specific file. If I start a new file and do a match properties on a viewport and apply it to another viewport, it works. In this specific file it does not. The settings for the MP tool are the same in both places. Any ideas? I feel like there was a setting that affected this, but I can't remember it.
    Thanks
    Mark
    2015-12
    Chesterfield, MI
    405
    Default Re: Match Properties
    Is it not saving the match or is it not even changing it in the active session?
    If it's not saving the match and you are referring to layer changes make sure that VISRETAIN is set to 1.
    2008-10
    45
    Quote Originally Posted by bcgatti View Post
    It's not changing in the active session. Visretain is set to 1 already.
    2015-12
    Chesterfield, MI
    405
    Is your viewport locked?
    Never mind this question. I just tested and the layer settings still "match" for me with locked vports.
    Last edited by Brett Gatti; 2009-02-20 at 04:45 PM. Reason: answered my own question...
    2015-12
    Chesterfield, MI
    405
    Could you post the problem file?
    2008-10
    45
    Unfortunately, I can't.
    2015-12
    Chesterfield, MI
    405
    It's too bad that you can't post it (but it is understandable). That would be the easiest way for someone to try to help you troubleshoot it.
    I could not duplicate that behavior in a couple of test files.
    Good luck with this one.
    Brett
    2008-10
    45
    Brett
    Thanks for trying!
    Mark
    2005-06
    in the upper right corner
    3,524
    Quote Originally Posted by mlf View Post
    Hello All,
    Thanks
    Mark
    A few questions:
    What version of AutoCAD are you using?
    Are you using xrefs or is the work in the same dwg file?
    What are you trying to "match" on the viewports?
    (if this is a 2008 layer states per viewport thing, I can't help you...sorry)
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Is this a rectangular viewport or irregular viewport? An easy way to tell would be to pick it and look at the top of the properties palette. Does it say All (2)? If so, it is an irregular viewport and I don't think Match Properties will work on it.
  1. Match Properties
    By Zia Farooqi in forum AMEP Wish List
    Last Post: 2009-07-05, 12:38 AM
  2. Match properties
    By Revit MEP DR in forum AMEP Wish List
    Last Post: 2006-11-01, 06:11 PM
  3. ADT Match Properties
    By Steve_Bennett in forum ACA Wish List
    Last Post: 2005-04-29, 08:07 PM
  4. Match properties
    By nanoaguilar2000 in forum AutoCAD General
    Last Post: 2004-12-28, 04:16 PM
