Thread: Topo Cut & Fill
    2008-10
    279
    Default Topo Cut & Fill
    Hi,
    Can someone tell me why only one of my topo's is scheduling please...
    It has calculated the cut and fill... but is only showing the new surface : |
    I used the copy - paste topo 1 - make topo 1 existing phase - edit topo 2 in new phase technique...
    ALSO - What has happened to my topography cut appearance??? It is just blanked out with no pattern...
    Thanks
    2004-06
    Memphis TN area
    7,048
    Default Re: Topo Cut & Fill
    There shouldn't be any copy/pasting going on. You either create a new toposurface, or import topo data from a survey to create the surface on the current phase. Then you either manually set it to existing and start a "graded region" by picking the existing topo (it will automatically demolish the existing), or you just pick Graded Region, and it will automatically move the topo to the existing phase and demolish it, and allow you to copy all the internal spot points to your new "graded" surface.
    For this reason, it's important to get the existing topo pretty correct based on your survey before you start grading. If you're importing topo data from a survey, there will often be "screwy" areas where you need to add a few points to get the topo lines to follow the lines on the survey.
    Once you get that all set up, then you can start your Graded Region.
    2006-12
    Maine
    57
    I agree. Use the Graded Region tool to do grading. This tool will automatically demolish the old surface and copy a new surface for grading purposes and help avoid errors of misaligned surfaces.
    For the Schedule, you are only getting one surface because the properties of the schedule have a Phase filter applied. It is probably set to only show new.
    All AUGI, all the time Gadget Man's Avatar
    2004-10
    Sunshine Coast, QLD, Australia
    607
    Checking THIS thread may be useful...
    2004-06
    Memphis TN area
    7,048
    Make sure to include the cut/fill amounts for the topo underneath any pads you may have, as the cut/fill for a graded toposurface does not include the cut/fill underneath pads.
    I found this out myself and posted about it here: http://forums.augi.com/showthread.php?t=93474
  1. Any way to get topo cut/fill data after the fact?
    Last Post: 2012-07-03, 09:15 PM
  2. Topo cut/fill reporting with pads?
    Last Post: 2009-11-04, 11:47 PM
  3. Cut and Fill from Topo Surface
    By Alan aka cadalot in forum Revit Structure - General
    Last Post: 2009-07-23, 12:29 PM
  4. Cut and Fill of Split Topo surfaces.
    By daniel.cocker in forum Revit Architecture - General
    Last Post: 2008-10-01, 12:15 PM
  5. Topo surface cut fill changes for each phase
    By gordolake in forum Revit Architecture - General
    Last Post: 2006-03-22, 01:57 AM
