Results 1 to 10 of 10
Thread: Trueview 2009 install error
    100 Club RobertAitken's Avatar
    2000-10
    Sunny Scotland
    148
    Default Trueview 2009 install error
    I'm having problems installing trueview 2009 on a new XP Pro laptop (Dell Vostro 1710).
    Downloaded a copy today (our previously downloaded copy didn't work either) and each time I try and install it I get an error message telling me that it didn't install (Fatal Error) and look at the log file.
    I've attached the complete log file.
    The laptop has .net 3.5 installed.
    Any Ideas/suggestions?
    thanks
    Robert Aitken
    2000-01
    Seattle WA USA
    5,859
    Default Re: Trueview 2009 install error
    We need the detailed log, not the overview.
    Do you have SP1 of .NET 3.5 installed?
    R. Robert Bell
    Design Technology Manager
    Stantec
    2000-10
    Sunny Scotland
    148
    Thanks Robert.
    It's attached as a zip file.
    As for .NET 3.5. Yes SP1 is installed.
    Thanks Again
    Robert
    2000-01
    Seattle WA USA
    5,859
    Well, the detailed log wasn't so informative either.
    So, back to basics, I guess.
    Have you disabled any virus scanner?
    Have you tried the downloaded installer on another machine?
    Have you downloaded the right bit version, i.e. are you running 64-bit?
    Are you executing the Setup.exe or improperly running the MSI?
    Are you installing from files extracted to the local hard drive?
    R. Robert Bell
    Stantec
    2000-10
    Sunny Scotland
    148
    Thanks again
    1. No AV Installed yet - last thing to get installed
    2. We have a downloaded version that is held on our network. That has been used as the default install on a number of machines. This copy was installed on another laptop gettting prepared at the same time. I also downloaded a fresh copy from Autodesk but I got the same error.
    3. Yes. 32 bit XP Pro, 32 bit Trueview
    4. Running the EXE file which then extracts to local C: then installs. Would like to use GPO but Autodesk don't like making things easy.
    5. See above answer
    Robert
    2000-01
    Seattle WA USA
    5,859
    Have you run MSI Clean and removed any current traces of DWG TV?
    R. Robert Bell
    Stantec
    2000-10
    Sunny Scotland
    148
    Nope.
    Will do on Monday when I'm back in the office.
    Thanks again
    Robert
    2000-10
    Sunny Scotland
    148
    Robert,
    Ran MSI Clean. no traces of DWG Trueview on the system. Removed .net3 and .net 3.5. Now they won't re-install.
    Got to the stage where I've just reload the OS on the laptop and started again.
    Will keep you posted on the outcome.
    thanks again
    Robert
    2000-10
    Sunny Scotland
    148
    Robert,
    Update on the Trueview troubles.
    After rebuilding the laptop and installing only the laptop drivers and .net 3.0, trueview 2009 installed and run wonderfully.
    All M$ updates appled and it's still working.
    Thanks for your assistance.
    Robert Aitken
    2000-01
    Seattle WA USA
    5,859
    Happy I was able to "help", although it seemed a drastic "solution".
    R. Robert Bell
    Stantec
  1. Error Message on 2009 Install
    By sarah.campden in forum Software
    Last Post: 2010-02-23, 05:36 AM
  2. Hidden commands you can use in Trueview 2009
    By NerdlingOne in forum DWG TrueView - General
    Last Post: 2008-12-22, 01:31 AM
  3. Trueview 2008 with AutoCAD 2009 dwg
    By jim.vipond in forum DWG TrueView - General
    Last Post: 2008-12-22, 01:29 AM
  4. DWG TrueView 2009 is now available
    By rkmcswain in forum DWG TrueView - General
    Last Post: 2008-03-26, 06:56 PM
  5. TrueView 2007 install errors
    By DarrenYoung in forum DWG TrueView - General
    Last Post: 2006-04-25, 12:14 AM
