Thread: Pasted object come in on Bound layers
    2001-01
    265
    Default Pasted object come in on Bound layers
    Hi All-
    I ran into a peculiar problem which I have never seen or heard of before. When I copyclip from one drawing to another in AutoCAD 2009, the object layers come in with a bound layer extension. I have checked the original drawing file to make sure that layers are not bound and they are not. Has anyone experienced this problem and how do I fix it? Thanks in advance.
    Manuel A. Ayala
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Re: Pasted object come in on Bound layers
    When I paste as block from the clipboard it does not change the layer.
    Does the block your pasting contain an xref? Does this happen with all pasted blocks? Try copying a circle to the clipboard and then pasting it as a block.
  1. FLATSHOT Which maintains object LAYERS
    Last Post: 2015-06-25, 01:26 PM
  2. Replies: 0
    Last Post: 2012-12-05, 11:16 PM
  3. Access Object Sub-entity Layers via the API
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-07-24, 06:57 PM
  4. Renaming Bound Xref Layers
    By de-co1 in forum ACA General
    Last Post: 2006-01-30, 09:36 AM
  5. Bound xref layers
    By jhohman in forum AutoCAD General
    Last Post: 2004-08-05, 03:30 PM
