Using PUBLISH set up one or several sheets you wish to plot with pagesetup1 (use your page setup name).
Now select all of those sheets wth pick (first one), hold shift, select the last one, right click, copy selected sheets.
You now have copies of those sheets listed, select only the new ones, pick the drop down for page setup and pick pagesetup2.
Repeat as necessary. You can plot a sheet to a large plotter, a laser jet, make a PDF, etc. all at once.
Save this setup so you can come back when ever you need to during the project.
Sorry if this is a repeat, I did a search and didn't find it.
