Thread: viewport reactor
    Member n_withers's Avatar
    2001-01
    Kalamazoo, MI
    42
    Default viewport reactor
    I have created a reactor that turns off the "navvcubedisplay" when in modelspace or a viewport. The viewport part only works when moving to a viewport from paperspace, not when moving from one viewport to another. Is there some kind of reactor that would fire when moving from one viewport to another, similar to the :vlr-layoutSwitched event for the vlr-miscellaneous-reactor when moving between layouts?
    Here is my code so far:
    (vl-load-com)
    (vlr-command-reactor "Turn Off Navvcubedisplay" '((:vlr-commandEnded . endCommand)))
    (defun endCommand (calling-reactor endcommandInfo / thecommandend)
    	(setq thecommandend (nth 0 endcommandInfo))
    	(cond
    		((= thecommandend "MSPACE") (setvar "navvcubedisplay" 0))
    		((= thecommandend "TILEMODE") (if (= 1 (getvar "tilemode"))(setvar "navvcubedisplay" 0)))
    	);end cond
    );end defun
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,657
    Default Re: viewport reactor
    You might need to look at the VLR-sysVarChanged reactor with the CVPORT system variable. Checking it along with the value of the NAVVCUBEDISPLAY variable, you should find a possible solution.
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Replies: 1
    Last Post: 2014-11-04, 03:32 PM
  3. vlr-dwg-reactor issue MY FIRST REACTOR
    By treaves04413213 in forum AutoLISP
    Last Post: 2013-10-18, 12:36 PM
  4. Replies: 1
    Last Post: 2009-08-14, 01:05 PM
  5. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
