Results 1 to 7 of 7
Thread: Can I create frequently used layer filters in LISP?
    2002-01
    99
    Default Can I create frequently used layer filters in LISP?
    Greetings, I have a set of layer filters I frequently use. For example, All ON, All OFF, All non-referenced (~*|*), All FAA (*FAA*), etc.
    Is there a way I can use LISP to create my favorite layer filters?
    Thanks for any help.
    2006-07
    233
    Default Re: Can I create frequently used layer filters in LISP?
    It seems there is a solution to your problem on the autodesk website. The lin is posted below.
    http://discussion.autodesk.com/forum...hreadID=456426
    2007-08
    202
    Hi,
    Here's an Import/Export layer filter LISP.
    It works with propety layer filters.
    EXPFLTR exports a layer filter from the current drawing to a text file (extention: .flt)
    IMPFLTR imports a layer filter from a flt file or a drawing.
    2007-11
    68
    Talking Re: Can I create frequently used layer filters in LISP?
    It would be nice if you could create a block with all your layers, lines types, & Layer filters in it. So far you can't import filters via a block. Maybe next autocad it will be released.
    2002-01
    99
    The LayerFilter.LSP does work, nice job. It only seems to do one at a time. I'd like to do several in one shot.
    I have not been able to get the AutoDesk forum post solution to work yet.
    I doubt you'll be able to import filters thru a block. This was enabled when layer filters first came out but it created drawings with thousands of filters so they disabled it.
    2021-08
    Thank you for your sharing, which is very helpful to me!
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    This is what I use the most:
    ; (load "LayFilterAdd.lsp")
    ; ^C^C^P(or LayFilterAdd (load "LayFilterAdd.lsp"));(LayFilterAdd)
    ; Newer versions automatically display Xref Layer Filters **Adding Xref Layer Filter names the same as them can cause serious issues**
    ; Save, close and reopen the DWT or DWG for the Filters to be put into alphabetical order.
    (defun LayFilterAdd (/ collection names)
    ;  (load "LFD.lsp")
    ;  (command "C:LFD" "All*") *Layers
      (setq names (list ""))
      (if (not (vl-catch-all-error-p (setq collection (vl-catch-all-apply
        (function (lambda () (vla-item (vla-getextensiondictionary (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) "ACAD_LAYERFILTERS")))
    ;  (vlax-for item collection (setq names (cons (strcase (vla-get-name item)) names))))
      (vlax-for item collection (setq names (cons (vla-get-name item) names))))
      names
      (or(member "CALC Points" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"V-NODE-CALC\" or NAME== \"Layer*\"" "CALC Points" "X" nil))
      (or(member "HATCH No xrefs" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"*HATCH\"" "HATCH No xrefs" "X" nil))
      (or(member "Linetype" names)(command "._-layer" "filter" "new" "property" "All" "LINETYPE==\"~Continuous\"" "Linetype" "X" nil))
      (or(member "Lineweight" names)(command "._-layer" "filter" "new" "property" "All" "LINEWEIGHT==\"~Default\"" "Lineweight" "X" nil))
      (or(member "NCS" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"[A,C,E,L,V]-*\" or NAME== \"Layer*\"" "NCS" "X" nil))
      (or(member "NCS No xrefs" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"[A,C,E,L,V]-*\" or NAME== \"Layer*\"" "NCS No xrefs" "X" nil))
      (or(member "No NCS" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~[A,C,E,L,V]-*\"" "No NCS" "X" nil))
      (or(member "No NCS or xrefs" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"~[A,C,E,L,V]-*\"" "No NCS or xrefs" "X" nil))
      (or(member "No NODE" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"[A,C,E,L,V]-*\" and NAME==\"~*-NODE*\" or NAME== \"Layer*\"" "No NODE" "X" nil))
      (or(member "NODE" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"~*|*\" and NAME==\"[A,C,E,L,V]-*\" and NAME==\"*-NODE*\" or NAME== \"Layer*\"" "NODE" "X" nil))
      (or(member "Profile" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-ROAD-PROF*\" or NAME== \"Layer*\"" "Profile" "X" nil))
      (or(member "Sections" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-ROAD-SEC*\" or NAME== \"Layer*\"" "Sections" "X" nil))
      (or(member "Topo" names)(command "._-layer" "filter" "new" "property" "All" "NAME==\"C-TOPO*\" or NAME== \"Layer*\"" "Topo" "X" nil))
      (princ "Layer Filter Names » ")(princ names)
    ;  (princ "\nSave, close and reopen the DWT or DWG for the Filters to be put into alphabetical order.")
      (princ)
    ); function
    (LayFilterAdd)
    You would have to modify it for your layers.
  1. LISP to create layer, hatch and set layer back to original.
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2013-12-11, 07:22 PM
  2. 2010: Can I use layer group filters for layer translation (LAYTRANS)?
    By Besni in forum AutoCAD General
    Last Post: 2013-10-04, 06:52 AM
  3. Create layer lisp problem in R2012
    By marc.verdaasdonk697335 in forum AutoLISP
    Last Post: 2012-12-04, 12:34 PM
  4. Ability to create legends from Filters
    Last Post: 2012-06-13, 02:32 AM
  5. Replies: 2
    Last Post: 2006-05-18, 01:39 PM
