Is it possibile create a new track by offset from a existing track in automatic ? ( in civil 3d 200
thank you
Mark
thank you
Mark
No. Not in 2009. You can offset an alignment and that will give you a polyline that you could then turn into an alignment.
Again, not in 2009 (nudge nudge wink wink say no more say no more)
2010 Has dynamic offsets for alignments! Plus much much more! wink, wink back at ya!Again, not in 2009 (nudge nudge wink wink say no more say no more)
Okay, so, I can create offsets to an alignment. I can even create a widening of the offset. I can even apply circular curves to the widening. BUT, how can I apply spiral-curve-spiral transitions to the widening?
Can I apply an angle to the transitions for the widening?
As far as I know, the transitions for the widenings on an offset alignment can't have spirals. If you need to have spirals, I think the only option is to create the offset alignment independantly of the centerline alignment.
Just a quick note on C3D 2010 Offset Alignments. These dynamically linked alignments are very powerful but when you offset a spiralled alignment, say using clothoid spirals, the resulting offset does not (CANNOT) employ true clothoids. This is not a limitation of the software, just a mathematical fact of life. There are two other methods for creating "nearly parallel" alignments with spirals that C3D does not discuss (yet) that are used by various transit agencies.
SRM
