Thread: Installing AutoCAD Architecture 2009 Object Enabler (32 bit)
    2009-03
    8
    Default Installing AutoCAD Architecture 2009 Object Enabler (32 bit)
    When I go to install AutoCAD Architecture 2009 Object Enabler (32 bit) for AutoCAD LT 2009, when I have to select the product I want configured with AutoCAD Architecture 2009 Object Enabler (32 bit) my AutoCAD LT 2009 porgram is displayed but I can not check off the check box next to it. Why is this happening?
    2009-03
    8
    Default Re: Installing AutoCAD Architecture 2009 Object Enabler (32 bit)
    To be put more simply: Can the AutoCAD Architecture 2009 Object Enabler (32 bit) be installed as a supplement to AutoCAD LT? Or is it just intended for use on the non-LT AutoCAD?
    0,0,0 The Origin
    8,570
    According to the adesk web site the answer should be "yes".
    2009-03
    8
    Quote Originally Posted by jaberwok View Post
    That's what it seems like, but I would like to hear from someone using AutoCAD LT 2009 that has had success installing these enablers. I had no problem installing them on a full version of AutoCAD but during installation of enablers with LT I could not select the program (LT) to configure.
  1. problems installing 64 bit Revit Architecture 2009
    By cvolans in forum Revit Architecture - General
    Last Post: 2009-12-17, 07:38 PM
  2. Civil 3D 2009 Object enabler
    By fusi in forum 3ds Max - General
    Last Post: 2009-03-18, 10:36 AM
  3. AMEP 2009 - Object Enabler for LT?
    By seventwo in forum AMEP General
    Last Post: 2008-12-15, 11:55 PM
  4. Installing Architecture 2009
    By ntormey in forum CAD Management - General
    Last Post: 2008-04-18, 04:43 PM
