Thread: Dyamic Blocks & Attribute Visibility
    2004-02
    Queensland, Australia
    3
    Cool Dyamic Blocks & Attribute Visibility
    Hi there,
    I am having this trouble with visibility of attributes attached to a block. The scenario is this; i have a CAD block symbol and it has two Attribute tags attached to it. One is changeable (attrib2) and ones a constant (attrib1). I add a visibility control to the block to control the two attributes and when they must display.
    Opt1. Display attribute 1 only; Opt2. Display attribute 2 only; Opt3. Don't display any attributes. Note, the symbol is always displayed throughout the 3 options.
    My problem is; this all works fine if the changeable attribute has no value, just leave blank. But when something is typed in, it totally ignores the visibility control set to it when Opt3 is chosen. Is this a BUGG!!
    PLEASE HELP!!
    2016-02
    Sydney, Australia
    512
    Default Re: Dyamic Blocks & Attribute Visibility
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    ALSO verify that you didn't just copy the attributes around and left them with the same names. Attributes won't behave at all if there's duplicate attribute names (tags)
    S&D DB Sharing Forum
    2004-02
    3
    Cool Re: Dyamic Blocks & Attribute Visibility
    I have checkout the threads mentioned but still not helping.
    I have attached the drawing file in mention
    cheers
    tank
    2004-02
    3
    Thumbs up Re: Dyamic Blocks & Attribute Visibility
    Thanks for that Chris. Golden Rule never copy your attributes.
    I can stop pulling my hair out now.
    Cheers
    tank
  1. Please, help me extract data Dynamic Blocks and Attribute blocks to Excel
    By minhphuong.humg453254 in forum Dynamic Blocks - Technical
    Last Post: 2014-04-17, 08:12 PM
  2. DB attribute visibility not working.
    By M. Kubitza in forum Dynamic Blocks - Technical
    Last Post: 2009-08-20, 02:56 PM
  3. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
  4. Dyamic Blocks & attext
    By k1w1_guy in forum AutoCAD Customization
    Last Post: 2005-09-15, 07:51 AM
