Thread: Importing shp files with object data
    2008-12
    5
    Default Importing shp files with object data
    In past versions I have been able to import shp files with object data on them where the object data table name and drawing layer was the same as the shp file name. Now in 2009, when I use mapimport command it appends 'Default_' to the beginning of the Darwing Layer and Object Data table name and cuts off the end of the original name (i.e. 'communicationscable_ohp' is now 'Default_communicationscab'). Does anyone know if there's a system variable to change or any other method to fix this?
    Thanks in advance,
    Allison
    TN/KY Area
    1,640
    Default Re: Importing shp files with object data
    There is no variable that controls that, it's a know issue that has been reported to the developers for a while. You have to manually type in the name of the tables during the import and rename the layer after the import.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2008-12
    5
    Thanks for your reply. Do you know if this is something they have fixed in 2010?
    TN/KY Area
    1,640
    From what I have seen the OD Table name is still prefixed with Default_ in the early builds of 2010. We can only wait on the final build to see what it does.
    J. Murphy
    AKA
    Murph
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. 2012: Hatches, object data and shape files HELP
    By dlh340951 in forum AutoCAD General
    Last Post: 2013-05-01, 06:39 PM
  3. Importing to object data?
    By LLCOOLJMARION in forum AutoCAD Map 3D - General
    Last Post: 2010-09-30, 10:38 PM
  4. need help....Importing Map entities and object data into google earth?
    By jmeyer.186809 in forum AutoCAD Map 3D - General
    Last Post: 2010-03-13, 12:13 PM
  5. Importing digital elevation data files...
    By vaughnmr in forum Revit Architecture - General
    Last Post: 2005-11-12, 01:54 AM
