In past versions I have been able to import shp files with object data on them where the object data table name and drawing layer was the same as the shp file name. Now in 2009, when I use mapimport command it appends 'Default_' to the beginning of the Darwing Layer and Object Data table name and cuts off the end of the original name (i.e. 'communicationscable_ohp' is now 'Default_communicationscab'). Does anyone know if there's a system variable to change or any other method to fix this?
Thanks in advance,
Allison
