you could try this, it puts the text on the annotation layer, and it gives you a couple more options. Option 3 sounds like what you want. It is supposed to drop the text at the midpoint of the object selected, rotated parallel (or tangent) to the object at that point.
(defun MakeLayer (lyrname acDoc / lyrobj)
(vl-load-com)
(if
(not
(vl-catch-all-error-p
(setq lyrobj
(vl-catch-all-apply
'vla-add
(list (vla-get-layers acDoc) lyrname)
) ;_ end of vl-catch-all-apply
) ;_ end of setq
) ;_ end of vl-catch-all-error-p
) ;_ end of not
lyrobj
) ;_ end of if
) ;_ end of defun
(defun c:lengthtext (/ lengthmode object
objchk listobj vlobj
MidPoint Param startpline
endpline vlobjlen1 angle1
Ang TH vlobjang
textobj1 textobj2 vlobjang1
vlobjang2 lengthscale lyrobj
(if (not (tblsearch "Layer" "Annotation"))
(if (setq lyrobj (MakeLayer "Annotation" acadDocument))
(progn
(vla-put-color lyrobj acgreen)
(vla-put-plottable lyrobj :vlax-true)
(vlax-release-object lyrobj)
) ;_ end of progn
(setq errmsg "\nLayer Make failed for Annotation layer")
) ;_ end of if
) ;_ end of if
(setq lengthmode
(getint
"\nSpecify Mode (1 = One Decimal, 2 = Two Decimals, 3 = Two Decimals with Bearing"
) ;_ end of getint
lengthscale (atoi (vl-string-left-trim
"1234567890"
(getvar "cannoscale")
) ;_ end of vl-string-left-trim
) ;_ end of atoi
) ;_ end of setq
(if (= lengthmode 3)
(setq
object
(ssget
(list
(cons 0
"ARC,LINE"
) ;_ end of cons
) ;_ end of list
) ;_ end of ssget
) ;_ end of setq
(setq
object
(ssget
(list
(cons 0
"POLYLINE,*CONTOUR,ARC,LINE,LWPOLYLINE,2DPOLYLINE"
) ;_ end of cons
) ;_ end of list
) ;_ end of ssget
) ;_ end of setq
) ;_ end of if
(while (setq listobj (ssname object 0))
(setq vlobj (vlax-ename->vla-object listobj))
(if (/= (cdr (assoc 0 (entget listobj))) "ARC")
(setq vlobjlen1 (vla-get-length vlobj)
objchk 1
) ;_ end of setq
(setq vlobjlen1 (vla-get-arclength vlobj)
objchk 2
) ;_ end of setq
) ;_ end of if
(setq MidPoint (vlax-curve-getpointatdist
vlObj
(/ vlobjlen1 2)
) ;_ end of vlax-curve-getpointatdist
Param (vlax-curve-getParamAtPoint VlObj MidPoint)
startpline (vlax-curve-getStartParam VlObj)
endpline (vlax-curve-getEndParam VlObj)
angle1 (vlax-curve-getFirstDeriv
VlObj
(/ (- endpline startpline) 2)
) ;_ end of vlax-curve-getFirstDeriv
TH (* 0.08 lengthscale)
) ;_ end of setq
(if (= objchk 1)
(progn
(if (equal (car angle1) 0.0 0.01)
(setq Ang (/ pi 2))
(setq Ang (atan (/ (cadr angle1) (car angle1))))
) ;_ end of if
(setq
vlobjang (angtos Ang 4 3)
vlobjang1 (vl-string-left-trim "NS 0123456789" vlobjang)
vlobjang2 (vl-string-right-trim
"EW \"0123456789'"
vlobjang
) ;_ end of vl-string-right-trim
vlobjang2 (vl-string-right-trim "d" vlobjang2)
vlobjang (strcat vlobjang2 "%%" vlobjang1)
) ;_ end of setq
) ;_ end of progn
(setq
Ang (- (/ (+ (vla-get-endangle vlobj)
(vla-get-startangle vlobj)
) ;_ end of +
2
) ;_ end of /
(/ pi 2)
) ;_ end of -
vlobjang2 (vl-string-right-trim "EW \"0123456789'" vlobjang)
) ;_ end of setq
) ;_ end of if
(cond
((= lengthmode 1)
(if (wcmatch (rtos vlobjlen1 2 1) "*`.*")
(setq vlobjlen (strcat (rtos vlobjlen1 2 1) "'"))
(setq vlobjlen (strcat (rtos vlobjlen1 2 1) ".0'"))
) ;_ end of if
(setq textObj1 (vla-addtext
acadModelSpace
vlobjlen
(vlax-3d-point Midpoint)
TH
) ;end vla-addtext
) ;end setq
((= lengthmode 2)
(cond
((wcmatch (rtos vlobjlen1 2 2) "*`.##")
(setq vlobjlen (strcat (rtos vlobjlen1 2 2) "'")
) ;_ end of setq
((wcmatch (rtos vlobjlen1 2 2) "*`.#")
(setq vlobjlen (strcat (rtos vlobjlen1 2 2) "0'")
) ;_ end of setq
((wcmatch (rtos vlobjlen1 2 2) "*")
(setq vlobjlen (strcat (rtos vlobjlen1 2 2) ".00'")
) ;_ end of setq
) ;_ end of cond
(setq
acadModelSpace
vlobjlen
TH
) ;end vla-addtext
) ;end setq
((= lengthmode 3)
(cond
) ;_ end of setq
) ;_ end of setq
) ;_ end of setq
) ;_ end of cond
(setq
acadModelSpace
vlobjlen
TH
) ;end vla-addtext
textobj2 (vla-addtext
acadModelSpace
vlobjang
TH
) ;_ end of vla-addtext
) ;end setq
) ;_ end of cond
(vla-put-color textobj1 256) ;change color
(vla-put-alignment textobj1 13) ;change justification
(vla-put-textalignmentpoint
textobj1
) ;_ end of vla-put-textalignmentpoint
;change insetion point
(vla-put-rotation textobj1 Ang)
;change rotation
(vla-put-layer textobj1 "Annotation")
(if (/= textObj2 nil)
(progn
(vla-put-color textobj2 256)
(vla-put-alignment textobj2 13)
textobj2
(vlax-3d-point
(list
(+ (car Midpoint) (* (sin ang) (* 0.16 lengthscale)))
(- (cadr Midpoint) (* (cos ang) (* 0.16 lengthscale)))
(caddr Midpoint)
) ;_ end of list
) ;_ end of vlax-3d-point
(vla-put-rotation textobj2 Ang)
(vla-put-layer textobj2 "Annotation")
) ;_ end of progn
) ;_ end of if
(ssdel listobj object)
) ;end while
) ;end defun
