Thread: Autocad 2007 - network/standalone
    2009-03
    3
    Smile Autocad 2007 - network/standalone
    Hello there.
    I'm a student from Clackamas Community College Oregon City, Or.I Have Autocad 2000 License Version. I need help changing a network version of Autocad 2007 to a stand alone
    version. I'm not sure how to go about it HELP!!!!
    Thank You JHB
    Earth
    9,819
    Default Re: Autocad 2007 - network/standalone
    Do you have the correct serial number for the 2007 standalone?
    If so, just uninstall the network version and re-install AutoCAD as a standalone (assuming your standalone version is on media and not a pre-built deployment)
    R.K. McSwain | CAD Panacea |
    If you mistakenly installed AutoCAD 2007 as a Network version or a Stand-Alone version, you can easily change a registry setting to revert to the appropriate version.
    If you are going from Network to Stand-Alone, you will need to authorize your copy and get the new 60-digit authorization code. Make sure the serial number you used to install is a stand-alone serial number or it will not be able to authorize. Alternately, you can run AutoCAD as a 30-day trial this way.
    2001-12
    St. Louis
    5,412
    Quote Originally Posted by beakzone333 View Post
    Hello there.
    Thank You JHB
    Hi, I've moved this thread from the "New Users Forum (non-technical)" to the "AutoCAD General Forum", as I believe it will be better served here.
    Thank you.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Standalone to network
    By bparrell in forum NavisWorks - General
    Last Post: 2009-07-17, 08:47 PM
  2. Can Network & Standalone Work Together?
    By RICHARD_JONES in forum CAD Management - General
    Last Post: 2007-10-05, 12:54 PM
  3. AutoCAD 2007 Standalone authcode for network version
    By ron.sanpedro in forum CAD Management - General
    Last Post: 2007-06-25, 02:08 PM
  4. Change a network install to a standalone
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2007-06-12, 04:08 PM
  5. Can't access content on network using standalone
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2004-01-16, 09:35 PM
