Has anyone tried running AutoCAD through a Citrix software environment or a MS Terminal Services environment?
Client is thinking/wanting to run AutoCAD through Thin Clients in a separate location.
Thanks
Charles
Thanks
Charles
Hi
Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
ID: TS70909 - Autodesk® software hosted on Citrix® MetaFrame® terminal servers or Windows® terminal server
ID: TS83877 - What are the supported operating system platforms for AutoCAD® 2005 based products?
Have a good one, Mike
