Results 1 to 9 of 9
Thread: Move a group of points
    2003-07
    Crestview, Florida
    29
    Default Move a group of points
    I am on C3D 2009. I have points inserted in c3d via the import points command. I have a group I have made of some certain points I wish to move. LDD did this function very easily. Where is that function in C3D?
    2003-07
    Crestview, Florida
    29
    Unhappy Re: Move a group of points
    Anyone? Any ideas?
    2007-08
    69
    Default Re: Move a group of points
    How about the move command (the regular Autocad one)?
    Unless you are using the survey database, in which case I think you have to modify the point in a different way. I don't use the survey database enough to know the correct way to do it.
    2003-07
    Crestview, Florida
    29
    I would like to use the same edit commands that are available in LDD. However, the move or rotate etc commands are not anywhere to be found. The regular move command would work if I could determine how to select a group of points to apply the move to. I want to select a predefined group of points. Picking them one by one is out of the question in this case.
    2007-08
    69
    You can do the free way and use the point groups by having the _All Points Group not show any marker or label and then move the point group you want to move to the top of the Point Groups order. This way only the point group you want to move will be visable.
    Or you can check out the Sincpac http://www.quuxsoft.com/SincpacC3D_H...MovePoints.htm I'm not sure if the move points command is in the free version though.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Yes, the MovePoints command is in the Free Version.
    The Free Version also has the SELPTGROUP command, which lets you select points on the screen by Point Group. You can then use the selection set for other commands. For some commands, you may need to first use the SELPTGROUP command to select the points, then run the other command. Then, when prompted to "Select objects", type "P" (for Previous selection set). This way, you can select points by Point Group, and then run almost any command on the points.
    2003-07
    Crestview, Florida
    29
    So what I am reading is that this C3D is woefully inadequate for basic survey commands and work performed on an every day basis. Is there anyone at AUGI reading this or any moderators that have any knowledge of the 2010 version having these functions restored? Ive used Adesk for the last 14 years and every year the software seems to lack more and more.
    2008-06
    The Yay! (Bay Area, CA)
    131
    Quote Originally Posted by eduley View Post
    I as well have been using autocad for about 15 years now and I would like to give a BIG HUGE AMEN BROTHER!. It's like we share the same brain.
    2011-08
    8
    Looking for older version exe file for Civil3D 2009. There is not one available on QUUX site.
    Can anyone help?
    THX in advance
  1. Move Points and Figures
    By SRBalliet in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-20, 11:47 AM
  2. Move a DIM String as a Group
    By MARPOW in forum AutoLISP
    Last Post: 2007-09-14, 01:17 PM
  3. Dimension points do not move when using the Move command
    By sudhirkizhakoote in forum AutoCAD General
    Last Post: 2005-10-16, 05:33 PM
  4. MOVE A GROUP OF OBJECTS
    By srae1977 in forum VBA/COM Interop
    Last Post: 2005-07-05, 04:23 PM
