G'day Gang!
This is another one that's been bothering me as well...
When I imported the 3D contour lines from AutoCAD to make site topography, sometimes, the contour lines just REFUSE to conform the the shape of the imported contour line (it seems to intepolate/ have a mind of it's own) I tried to use different contour display intervals, and sometimes this method works, but sometimes it doesn't. This is especially frustrating because you KNOW some of the contour MUST pass certain points (critical part such as building edges) and it just isn't showing up and that makes the contour kinda useless.
Is there any way to FORCE Revit to confrom to the contour line??
(On a side note, I found this problem especially apparent when you have a "S" type contour line.. a "S" contour would usually mean that the same height contour points are bunched together and hence Revit would inteprete as a large area of plain and hence only contour the outline of this area)
I have also another question, is there any way to import point data? I get lots of spot elevational point data, and to manually put individual points in is a pain in the buttock..
