cliff collins
1. Use a stacked wall for the different colors/materials. Create each wall type
individually with its material/color. Then create a stacked wall which combines all the
wall types together.
2. For the Sweep, try embedding it into one of the wall types which is inserted in the stacked wall. Go to Structure Edit, Sweeps, and add a profile for the sweep, and it's location on the wall.
3. If you need the material for the sweep, try an in-place family sweep, instead of a hosted wall sweep--I think you can then get a material from the sweep if needed--and if I remember correctly, you can not schedule a material from a hosted sweep.............
