Thread: Revit 2008 on Vista 64 Activation issue.
    All AUGI, all the time Les Therrien's Avatar
    2003-05
    Tecumseh, Canada
    623
    Question Revit 2008 on Vista 64 Activation issue.
    First off, I know the 2008 is old news. But I still use it for some older files that I don't feel like upgrading.
    Anyways, here's the deal. I was forced into an upgrade and decided to try the 64 bit system again.
    There have been some pains and hiccups, but I'd say I've got things to about 90% so far.
    Aside from the materialprotein library in 2009, my only big remaining issue is Revit 2008.
    Initially it loaded in fine. There were no issues whatsoever until a few days ago.
    I don't know enough to make an educated statement on the issue, but the problem seems to have started right after I uninstalled 2009 trying to get that working properly.
    Anyways 2008 suddenly started asking to be activated!
    I enter my serial number then request an activation code then I get a processing error.
    It gives me a request code and a note saying a customer service rep will respond within a couple days. Well that was a week ago.
    I've also tried using the request code on the Autodesk site, but it doesn't work there either.
    I've tried uninstalling (and deleting as many files as i could find that don't delete) and reinstalling but that doesn't work either.
    Does anyone have any advice on this????? I'm getting desperate.
    2003-05
    Tecumseh, Canada
    623
    Default Re: Revit 2008 on Vista 64 Activation issue.
    bump.
    anyone?
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    I think that activation problems need an Autodesk solution. I haven't a clue. I would make a subscription support request. They're sitting by the phones waiting for your call
    2007-06
    Melbourne, Australia
    602
    Have a look here http://forums.augi.com/showthread.ph...protein&page=3
    about half way down the page was the advice I got from Autodesk on how to completely remove earlier elements to do a clean install.
    Cheers,
    Ian
    2003-05
    Tecumseh, Canada
    623
    thanks guys!
  1. FireGL Vista-64 Revit MEP 2010 Blank Screen / Driver issue
    By mlmiller1 in forum Revit MEP - General
    Last Post: 2009-04-17, 01:26 AM
  2. switching to Vista 64 - Revit activation switching
    By ws in forum Revit Architecture - General
    Last Post: 2008-06-08, 10:02 AM
  3. Replies: 2
    Last Post: 2008-05-01, 04:07 PM
  4. Raccourcis clavier Revit 2008 sur Vista
    By jlevy-BSA in forum Revit Architecture - General
    Last Post: 2008-03-06, 10:01 PM
  5. HELP!!!! issue on R8 activation
    By p.vicini in forum Revit Architecture - General
    Last Post: 2005-05-25, 05:33 PM
