Assuming that you open a file, then do a fair amount of work, QSave a few times.Then realize that you should have saved the file to a new name.
If you have not closed the drawing there is a way to save the work and restore the drawing back to the Original state.
Method 1:
Step 1) TYPE in "Save". and input the new file name.
(Note: Do not pick "Save" off a pull down or a toolbar as that will "QSave" to the current file name. It's interesting to note the difference between QSAVE, SAVE, & SAVEAS when typed at the command prompt. IF a drawing has been named, SAVE will make a copy of the drawing in what ever path you choose. IF you use the same path & name as the current drawing it will prompt for "overwrite". Otherwise it will make an exact copy but with a new name.)
Step 2) Use "Undo" "B" "Y" to get back to the original state.
Step 3) Qsave the drawing.
Method 2:
Replace Step 1 in the previous example with this
Step 1) use the "Wblock" command and select "Entire Drawing" and assign the new name in the path.
then follow steps 2 & 3 in the previous example.
Method 3:
Step 1) in windows explorer find the file and copy it, paste it in the new location (if needed) then rename it.
Then in AutoCAD follow Steps 2 & 3 as mentioned in the previous example.
