Thread: Migrating from 2009
    2004-11
    Wisconsin
    302
    Default Migrating from 2009
    I inadvertantly canceled the migration of the from 2009 to 2010, is there a way to do it after the fact without reinstalling?
    thanks
    John Fleming
    GMK Architecture, inc.
    2004-11
    Wisconsin
    302
    Default Re: Migrating from 2009
    nevermind, figured it out.
    2003-03
    Philadelphia, PA
    2,392
    Quote Originally Posted by johnf.77896 View Post
    Care to share what you learned, in case others find themselves in a similar situation?
    We do not move to new releases very often at work, and at home I have avoided using the migration utility. I keep my customizations in separate CUIs/files, and make copies to manually bring into the next release. At one time, there was a recommendation that ADT/ACA users not use the AutoCAD migration utility, but perhaps more recently the migration utility has been made ACA-friendly. I would be interested to hear what your experience has been.
    2004-11
    Wisconsin
    302
    Sure David, it is as simple as going to the start menu and navigating to the AutoCad2010 pulldown in "all programs" "Autodesk" "AutoCAD Architecture 2010" "Migrate Custom Settings" "Migrate from a previous release" and that is it, run it.
    John Fleming
    2002-09
    Madison, WI
    5,688
    Hi John,
    Please note that I've moved this thread to the new ACA2010 forum.
    Thanks
  1. CM219-1P: Migrating from MNU to the CUI
    By Autodesk University in forum CAD Management
    Last Post: 2013-05-05, 03:15 AM
  2. migrating to 64 bit from 32
    By tomm in forum Revit Architecture - General
    Last Post: 2010-09-22, 04:14 PM
  3. Migrating from ACAD
    By asaastad in forum Revit Structure - Families
    Last Post: 2007-04-09, 10:41 PM
  4. Migrating to ADT 2007
    By markjohn.perry in forum ACA General
    Last Post: 2006-11-08, 06:21 AM
  5. Migrating for .idw to .dwg
    By danang_061 in forum Inventor - General
    Last Post: 2005-08-30, 01:51 AM
