Results 1 to 6 of 6
Thread: Color Scheme Shows in Section But Not in Plan View
    2005-01
    Christchurch, New Zealand
    11
    Question Color Scheme Shows in Section But Not in Plan View
    One of my users has got a baffling query, he has applied a Color Scheme for his project and in plan view all the rooms show the appropriate colour except one room, the room boundary, view range, visability graphics etc etc are all correct but no colour is shown. In a section view the colour is visable!!
    Has anyone else had a similar problem? I know that 2008 had problems with Color scheme and stairs but I've never had any problems before this in 2009.
    Any help is much appreciated
    Member robin.capper's Avatar
    2002-06
    New Zealand
    48
    Default Re: Color Scheme Shows in Section But Not in Plan View
    Sounds nuts but try deleting and re-adding the room. I had similar with a room that was valid in Revit Arch but did not appear/show in Revit MEP. After wasting a lot of time just deleting the problem room and recreating it solved the problem
    2005-01
    11
    Hi Robin
    Thanks for the reply, deleting the room was one of the first things I tried, strangly when I delete the room then add in within the boundaries of the problem room a smaller room using room separating lines the color scheme shows up fine in both plan and section.
    2006-03
    London, UK
    810
    This is a problem I've had, and I remember solving it, and I remember the solution being something to do with the walls, but now I can't remember >_<
    Sorry!
    2002-06
    New Zealand
    48
    One other time I had this an inadvertently duplicate wall overlap was the cause
    2007-07
    Charleston, SC
    50
    I just ran across something similar, I was adding room separation lines, one end of the separation line overlapped a plan region slightly. The color wouldn't show, and the Room area was something like 100x too big! I just moved the plan region boundary over a bit, re-drew the room separation line, then moved the plan region boundary back over and it worked fine. FYI
  1. Apply Color Scheme to Floor Plan View
    By fwp in forum Revit - API
    Last Post: 2012-09-10, 08:25 PM
  2. Area Plan Color Scheme in 3D view
    By laura92101 in forum Revit - Rendering
    Last Post: 2009-05-26, 08:43 PM
  3. Color Scheme in 3d section view
    By t1.shep in forum Revit Architecture - General
    Last Post: 2008-12-11, 10:48 PM
  4. Color Scheme Legends - Not on Plan but still in Legend?
    By saeborne in forum Revit Architecture - General
    Last Post: 2008-10-28, 08:12 PM
  5. view file of plan always shows justifications
    By sharla in forum ACA General
    Last Post: 2007-09-06, 03:07 PM
