Thread: AutoCAD is changing my blocks
    2008-10
    53
    Default AutoCAD is changing my blocks
    i have my title block split into two differant blocks one that applies to the entire sheetset and one that applies only to the individual sheet. my problem is that when i insert the block ofr the sheet and save it at some point within 24 - 48 hours the block will be replaced with an AutoCAD generated block. it looks almost like the original but the text is black. and it moves a little.
    Any ideas would be gratly helpfull.
    thanks in advance
    Chesterfield, MI
    405
    Default Re: AutoCAD is changing my blocks
    When you say it is replaced with an "AutoCAD generated block" - how did you determine this (as opposed to an accidental overwriting of the block)?
    Are you Xref'ing the block into your files or are you inserting it?
    Is anyone else working on this file - someone who could have replaced or redefined this block?
    2008-10
    53
    if someone eles is replacing the blocks then they are creating blocks with names like a$1$acadle345. that is why i thought they were autocad generated blocks they are also very similar to the correct blocks there will only be one or two little changes like plot style or text size that kind of stuff.
    2015-11
    Jo'burg SA
    4,512
    Some extra info needed:
    1. What ACad version and vertical
    2. Is the block a dynamic block?
    3. Do you use annotative scaling, if so do you save back to an older DWG version?
  1. Changing rotation angle of blocks using lsp
    By ReachAndre in forum AutoLISP
    Last Post: 2014-08-06, 07:45 PM
  2. changing properties in blocks en masse
    By Maverick91 in forum Dynamic Blocks - Technical
    Last Post: 2013-02-20, 06:21 PM
  3. Changing the layer of objects in blocks
    By .chad in forum ACA General
    Last Post: 2008-10-29, 07:41 PM
  4. Blocks Changing Names
    By amandas in forum AutoCAD General
    Last Post: 2008-08-29, 06:01 PM
  5. Changing object colours in blocks
    By cadmecheng in forum AutoCAD LT - General
    Last Post: 2006-05-04, 12:53 AM
