Results 1 to 8 of 8
Thread: DWG layers keep coming back!
    2008-06
    Adelaide, South Australia
    279
    Default DWG layers keep coming back!
    Has anyone got any idea why the layers on a linked DWG keep coming back?
    I've linked in several DWGs and since I don't want to see the grids, wall hatching, defpoints, etc. I've been going through and querying the objects, and deleting the layers.
    The DWG files have NOT been updated since then, and yet every now and then when I open my project all the layers have come back on!
    It's starting to take up copious amounts of time cleaning up all the DWGs.
    I can understand it resetting if the DWGs were updated but when they haven't been opened at all, or reloaded, why would it forget my settings?
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Re: DWG layers keep coming back!
    You need to set the visibility in the linked drawing, rather than delete layers, as the drawing is loaded fresh every time you start Revit.
    I'm not fully up to speed on the how of the linked visibility, but I am certain that this is where your issue is coming from.
    Alternately, open the dwg, and turn off/frezze the layers you don't want to see.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2008-06
    279
    What do you mean by "Set the visibility in the linked drawing"?
    It isn't EVERY time I start Revit. It happens with varying frequency. Can happen twice in a week to 5 times in a day.
    Freezing off layers isn't really a good idea for us since we have multiple disciplines using the drawings for different things in different packages (elec and mech in Revit, hydraulics and fire in ACAD and Revit, Struc in Revit, civil in 12D(?)).
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Quote Originally Posted by schrodingerscat View Post
    ...Freezing off layers isn't really a good idea for us since we have multiple disciplines using the drawings for different things in different packages (elec and mech in Revit, hydraulics and fire in ACAD and Revit, Struc in Revit, civil in 12D(?)).
    How about turning off the offending layers in V/G Overrides?
    2008-06
    279
    That would be a solution... except that new layers keep coming in, things that were on one layer keep ending up on different layers, I have 42 drawings to do this on, and each type of object seems to have 4 or 5 different layers they can be on with obscure names that would take a while to figure out.
    We're receiving new architecturals every few days and that solution would probably take more tie to sort out, just because they're inconsistent.
    2004-07
    Perth Australia
    736
    Quote Originally Posted by truevis View Post
    This is what I meant by setting visibility.
    Reseting during a session is wierd though, are you running any api, external apps etc that could be accidentally doing it?
    Perhaps offering to backcharge the architectural firm for needing to set their hatching etc onto approprate layers might propt them to try a little harder for consistency (of course if they are from different firms then it may not really be appropriate)
    Kathy Taylor
    TaylorCAD
    2008-06
    279
    The layers aren't reloading in a session unless I hit the reload button. What I mean is that each day I will reload the DWGs up to 10 times through restarting Revit, or simply reloading them, but every few times I do this it resets the layers. Inconsistently at that. It's not every single time they're reloaded, it'll happen and then the next time it won't, the next time it won't, and then it'll happen again.
    I'm not running any external apps. Thought I'd hold off writing any more until RMEP 2010.
    The biggest problem with that is we know the architecturals (and layers)are going to change. The completion date for the MEP drawings is 2 months before the completion date of the architecturals. Don't ask me how that works, I don't understand either, but the fact is that up until the very last issue we're going to be working with fluid drawings.
    2016-02
    Sydney, Australia
    512
    Sounds like it's a system variable in the AutoCAD file which is linked to the Revit file.
    Probably VISRETAIN :-
    0 The layer table, as stored in the reference drawing (xref), takes precedence. Changes made to xref-dependent layers in the current drawing are valid in the current session only and are not saved with the drawing. When the current drawing is reopened, the layer table is reloaded from the reference drawing and the current drawing reflects those settings. The layer settings affected are On, Off, Freeze, Thaw, Color, Ltype, LWeight, and PStyle (available only in named-plot style drawings).
    1 Xref-dependent layer changes made in the current drawing take precedence. Layer settings are saved with the current drawing's layer table and persist from session to session.
  1. Please bring the NON-PLOTTING icon back to the layers drop-down lists.
    Last Post: 2012-07-14, 03:44 PM
  2. Replies: 0
    Last Post: 2012-03-02, 09:18 PM
  3. XREF layers revert back after closing dwg?
    By cadman33619 in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-11-17, 01:55 PM
  4. Replies: 3
    Last Post: 2006-09-22, 08:22 PM
  5. Why that "Centre of Rotation" icon keeps coming back to its origin?
    By Gadget Man in forum Revit Architecture - General
    Last Post: 2005-01-03, 02:54 PM
