Is there a way to get raster images to display in front of geometry? Everytime I insert an image it disappears when it's behind anything. This is for 6.1, by the way.
We still can't rotate raster images in 7.0 (except 90deg), it makes it hard to trace a plan when it has to be scanned perfectly aligned, maybe it will be in the final version or 7.1, fingers crossed.
Kim
If you have access to AutoCAD, and I imagine Microstation, you can align in that and then import or link the DWG, if this is not an option then you can consider rotating in photoshop or another image editing package. Both are workarounds but will get you close to what you need.
Try a wireframe view. It'll show then.Is there a way to get raster images to display in front of geometry?
If you can't rotate the image, as Peter has suggested, try rotating the view to match the image. I've had some luck doing that. Turn on the view crop boundry, select the crop boundry, & either graphically rotate it, or type in the angle.We still can't rotate raster images in 7.0 (except 90deg), it makes it hard to trace a plan when it has to be scanned perfectly aligned,
Hi Armando,Originally Posted by ariasdelcid
Try this, it is great for scaling images! It was a tip & trick from Jim B.
Steve Shell
But it'll also show a whole lot of other stuff that I don't want to see! Thanks for the suggestion though. This seems to be something that needs fixing.Originally Posted by andrewg
Rotate command doesn't work on 'Raster images' in the way you have suggested.
What Andrew is saying is to rotate the view, not the raster image.
