Results 1 to 7 of 7
Thread: Autocad 2010 Ribbon
    2004-06
    Slidell, Louisiana
    865
    Default Autocad 2010 Ribbon
    Is there a way to make the tabs and panels on the ribbon with larger text and spread apart more. i am having trouble seeing them in such small print. also, is there a way to center them or move them to right side of the screen.
    Robert
    0,0,0 The Origin
    8,570
    Default Re: Autocad 2010 Ribbon
    Right-click the top menu bar (starts with "Home"), pick Undock and drag it into position.
    John B
    2004-06
    Slidell, Louisiana
    865
    Quote Originally Posted by jaberwok View Post
    What i was trying to say was, leave the menu bar where it is, just make the text and or spacing bigger. i am 50+ and my vision isn't what it used to be. i need the text and icons larger and easier to see. i do a lot of keyboarding, but sometimes the icons are handy. any help for the older folks would be appreciated.
    Robert
    0,0,0 The Origin
    8,570
    Ah, right.
    If you want to affect everything, you can do it in Windows itself.
    Right-click the desktop and select the Appearance tab. Change "Font size".
    John B
    2004-06
    Slidell, Louisiana
    865
    Thanks a bunch jaberwok, that did the trick
    Robert
    2009-09
    13
    I would still like to know if there actually is a way to center the ribbon without undocking it? I have customized my own Ribbon Tab and it doesn't fill up the whole ribbon (as I have a 17" widescreen monitor) so I would like to shift all the panels over to center them since most of my drawing is done in the center of the screen. It seems it would be more efficient to me but I doubt there's a way to do this.
    2009-11
    5,600
    Quote Originally Posted by jmerchant View Post
    Tell me about it... I work with dual 20" Widescreen Monitors!
    My desired button can be +/-30" *over there... keep going... on the left*. I too would love it if there was a way to center interface components, like the ribbon, toolbars, etc., without them being shoved back to the left side regardless of your saved workspace placement.
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. Replies: 0
    Last Post: 2014-12-01, 03:30 AM
  2. Autocad 2010 unable to change linetype on ribbon
    By etim001452344 in forum AutoCAD Customization
    Last Post: 2012-01-16, 04:27 AM
  3. AutoCAD MEP 2010 Ribbon Rant
    By stykface in forum AMEP General
    Last Post: 2009-10-07, 11:16 PM
  4. AutoCAD 2010 new Ribbon Panel Rows
    By curtis.hatfield in forum AutoCAD CUI Menus
    Last Post: 2009-09-14, 04:59 PM
  5. RS 2010 Ribbon
    By amacleod in forum Revit Structure - Wish List
    Last Post: 2009-05-07, 02:14 PM
