Hi All,
I have a couple of niggling installation problems with 2010.
Everything seemed to install ok - no error messages.
Firstly, on Start up of Revit, I get the attached error message at the end of the splash screen. Clicking through, Revit will start up OK and everything seems to work (rendering included). From time to time however, this error message will re-appear.
Secondly, when loading a component (or indeed loading a project), and if I attempt to change the view from list to icons Revit wants to install something it cannot find. A small routine starts up where it attempts to load installation files, is unable to find them and then simply quits. Again Revit will continue normally unless I try to view families or projects in any other view than list.
I have sent a support request, but maybe one of the Beta testers may be able to shed some light.
Cheers
Ian
PS First impressions - not too bad, I like the fact that one can hide the ribbon and get some more vertical screen real estate. Is much faster in 3d with shadows on. The ribbon itself is absolutely horrible (imho) but it will mean that it will force us to be better at keyboard short cuts
PPS
Vista 64 bit 8mg ram Duo core processor 64 bit Revit
