hi,
i am having problems with my scalelistedit comand. it seems that my computer or acad version brings in weird xref scales in even if there is no xref in the drawing. i attached the error details i get when i type it in.
anyone any idea how to get rid of that bug?
thanks gerit
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at Autodesk.AutoCAD.ApplicationServices.ScaleListHelpers.loadScaleList(String[] scaleStr, Double[] scaleNum, Double[] scaleDenom, Int32[] scaleCount)
at Autodesk.AutoCAD.ScaleList.ScaleListForm.Read()
at Autodesk.AutoCAD.ScaleList.ScaleListForm.restoreData(Boolean bResetIfNoData)
at Autodesk.AutoCAD.ScaleList.ScaleListForm..ctor()
at Autodesk.AutoCAD.ScaleList.Commands.ScaleListEditCmd()
at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgCommandClass.InvokeWorkerWithExceptionFilter(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgCommandClass.Invoke(AcMgCommandClass* , gcroot<System::Reflection::MethodInfo ^>* mi, Boolean bLispFunction)
at AcMgCommandClass.CommandThunk.Invoke(CommandThunk* )
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.1.0.0
Win32 Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.3053
Win32 Version: 8.00.50727.3053
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
acmgd
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/acmgd.DLL
AcXrefUtil
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcXrefUtil.DLL
AcInfoCenterConn
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AdInfoCenter.DLL
System.Windows.Forms
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.Interop.AcInetEngine
Assembly Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/Autodesk.Interop.AcInetEngine.DLL
AdInfoCenter.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/en-US/AdInfoCenter.resources.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
venalnts
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcLayer.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcMgdShared.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/acmgdinternal.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/en-US/AcLayer.resources.DLL
AcLayerTools
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcLayerTools.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/en-US/AcLayerTools.resources.DLL
AcScaleList
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/AcScaleList.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20LT%202008/en-US/AcScaleList.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
