Maybe not appropriate for this forum, but I'll try...
Installed NavisWorks 2010 first, then Revit 2010... How do I get the export to NavisWorks option from Revit?
I'll post in the Revit forum too.
Thanks!
Thanks!
You need to install NavisWorks last. If you repair your Navisworks installation it should add in the proper exporters for Revit..
I know that... but we currently are new to NavisWorks so I already have 2010 on a bunch of PC's. That was a no-brainer. We're holding off a bit before we upgrade to Revit 2010. So, this is a bigger issue when multiple PC's are involved... Especially since we're running network versions of the software and all installs are done via deployments.
I'll have to think thru this one.
Worked...
Had to repair/reinstall the Exporters.
Thnx.
