Results 1 to 6 of 6
Thread: Revit 2010 error after installation
    2008-04
    [EST]Tallin
    97
    Default Revit 2010 error after installation
    Hi !!!
    At first, sory for my englesh
    I'm new to REVIT. Had downloaded trial version of 2010 revit from autodesk download, succesfully installed with 00 serial (trial), trying to execute (run) software and get this message:
    "Revit could not load RevitMFC.dll"
    I have slow and old comp but 2009 running well on it, OpSys - WinXP Pro with SP3 installed.
    What can I do to resolve this problem ?
    THANK YOU !!!
    2008-05
    Brunei
    299
    Default Re: Revit 2010 error after installation
    First, check the size of the file you downloaded. If its not close 1.41GB. Then your download is incomplete. And that explain the error. Try to download again.
    2008-04
    [EST]Tallin
    97
    Hi!
    Size of downloaded file is 1,41 Gb.
    But here is another problem: it BIG difference between LOAD and FIND . I hered, that Revit 2010 want 4 gb (or more) of operating memory and my problem exactly here: revit can't LOAD dll file, because is too small memory size.
    That's all
    GOOD LUCK !!!
    2008-10
    I AM ALSO HAVING THE SAME ISSUE... ANY HELP ? BUT WITH REVIT STRUCTURE I DOWNLOADED THE FILE FROM AUTODESK, COPIED IT FROM MY WORK ( WHO HAVE A SUBSCRIPTION) AND STILL NOT WORKING ?
    2009-07
    Unhappy Re: Revit 2010 error after installation
    hi!i also hav a problem too. after the instllation n going to run the aplication n then nothing happen its only SECSpalshWindow n not responding.can u guy help me with this?
    thanx!
    100 Club mschroeder's Avatar
    2005-06
    Boston
    154
    Exclamation Re: Revit 2010 error after installation
    Error could not load RevitMFC.dll
    Journal:
    ' 0:< Initial VM measure: 1931 MB available, 37 MB used
    'C 05-Aug-2009 13:59:11.687;   0:< started recording journal file
    ' Build: 20090612_2115
    Dim Jrn
    Set Jrn = CrsJournalScript
    'C 05-Aug-2009 13:59:12.078;   0:< ->InitInstance
    ' 0:< VM Delta: Available -79 MB -> 1853 MB, Used +58 MB -> 96 MB
    ' 0:< MessageBox "Revit could not load RevitMFC.dll"
    ' 0:< Revit could not load RevitMFC.dll
    Here's another blog entry with same issue: http://revit-programmer.blogspot.com...tallation.html
    Also, it's a known issue:
    http://usa.autodesk.com/adsk/servlet...P=OTC-RSSSUP01
  1. Revit 2012 Installation Error
    By wes199518 in forum Revit Architecture - General
    Last Post: 2011-04-25, 10:06 PM
  2. Revit 2010 'Unrecoverable error has occurred' message after installation
    By daniel.stark in forum Revit Architecture - General
    Last Post: 2010-09-22, 02:19 PM
  3. Help!! ACAD MEP 2010 Installation Fatal Error
    By mike.weems in forum AutoCAD General
    Last Post: 2010-05-13, 05:39 PM
  4. Vault 2010 Server Installation error
    By davor in forum Vault - General
    Last Post: 2010-04-14, 01:43 PM
  5. Revit 2010 Installation problems
    By iankids in forum Revit Architecture - General
    Last Post: 2009-09-18, 07:27 AM
