Thread: NavisWorks 2010 to 2009 (xml file)
    2016-01
    San Francisco, CA
    293
    Default NavisWorks 2010 to 2009 (xml file)
    How do you make/convert the viewpoints (.xml) file created in 2010 and able to import it in 2009?
    100 Club steve.perkio's Avatar
    2006-05
    Riverside, California
    140
    Default Re: NavisWorks 2010 to 2009 (xml file)
    Anybody have any luck with this item??
    I need to send xml's from 2010 to people with 2009 also.
    Perk
    2016-01
    San Francisco, CA
    293
    I was told in the training center that it's not doable if it's the xml file.
    But you can save the file as a .nwf file (with all of the viewpoints saved)
    Then MERGE this .nwf file into your current file. Whatever viewpoints that are saved in the nwf will be "imported" to your current file.
  1. How create *avi from file navisworks 2010
    By dungtoannam in forum NavisWorks - General
    Last Post: 2010-04-14, 12:05 AM
  2. Opening Revit file done in 2010 in 2009
    By Joseph TVM in forum Revit Architecture - General
    Last Post: 2010-02-17, 02:33 PM
  3. NavisWorks 2010 File Format
    By OwenWhitehouse in forum NavisWorks - General
    Last Post: 2009-11-13, 05:13 AM
  4. Upgrading 2009 file to 2010 problems?
    By JayKurtz12 in forum Revit MEP - General
    Last Post: 2009-07-10, 07:23 PM
  5. 64b apps: autocad mep 2009 & navisworks 2010
    By mhutchinson.121719 in forum NavisWorks - General
    Last Post: 2009-05-06, 07:28 PM
