Thread: Acad dwg files in product stream
    2009-04
    Exclamation Acad dwg files in product stream
    What procedure is used to add AutoCad dwg files into Product stream. Some of these files are 10 years or more old I took a course of how to use Inventor Vault and Product stream but the never tolt us how to bring Acad dwg's in Product stream
    Thank You
    Sincerely William
    2007-04
    81
    Default Re: Acad dwg files in product stream
    There is an upload tool in PS, I would probably would look at taking your old data and saving it in the new release - at the very least test it.
    The other item i would look at doing prior to uploading is getting meta data (file properties) in the drawing files prior to uploading.
    hopefully this helps
    Patrick K. Johnson
    http://www.cadenhancement.com
  1. Can't specify which Autodesk product opens DWG files
    By stevenw00d in forum CAD Management - General
    Last Post: 2014-07-14, 05:19 PM
  2. Is a seat of Product Stream needed per seat of Vault?
    By Joy_1611 in forum Productstream - General
    Last Post: 2009-07-28, 03:46 PM
  3. Is a seat of Product Stream needed per seat of Vault?
    By Joy_1611 in forum Vault - General
    Last Post: 2009-07-28, 03:40 PM
  4. SDI = 1 and Vault/Product Stream Functions Available
    By BrenBren in forum AutoCAD Electrical - Wish List
    Last Post: 2009-02-01, 06:34 PM
  5. Multiple ACAD/Autodesk Product Installs
    By Mike Y in forum AutoCAD General
    Last Post: 2006-05-18, 12:09 AM
