For my drawings, I will set psltscale to 1 for every layout tab.
Every time I re-open any drawing the psltscale has switched back to 0
Any answers why it is doing this and how I can make psltscale stay at 1
thanks,
Mike
thanks,
Mike
If you set this variable, save the drawing, close it and reopen it and it's changed, then you almost certainly have something running at drawing startup that is resetting it to 0.
Check your "acad.lsp", "acaddoc.lsp", any .mnl files, the S::Startup function, etc.
That has nothing to do with it. The value of LTSCALE has no bearing on the value of PSLTSCALE.
R.K. McSwain | CAD Panacea |
Thanks, sounds like you are right with it being a startup issue, I will see if I can figure it out.
Mike
