Timeline- edit link to the new update program file, why the task type and Attached will lose all. the link.
What should I do to keep the task type and attached while edit the new program link.
find the attached:
find the attached:
You shouldn't lose data if it is the same program with modifications to existing activities, but if you are trying to update with a copy, or if your unique ID's are changing, it will not work.
What scheduling software are you using?
i used Primavera 6 software. thanks
